On the original bikes the breather had two outlets with a long hose going down, behind the engine. They found this blew to much oil out. Later they plugged one outlet and used just one hose. Even later the changed to a single outlet breather that was hooked into the air boxes.
On a bike with out the stock air boxes a short hose and the power brake check valve pointed at one of the pod air filters keeps any oil blowby going into the air filter instead of all over the bike.
A short hose and a filter , after the filter gets too wet with oil lets oil flow all over the bike.
I use a short hose, a brake valve and a long hose to behind and below the engine.
The check valve does create a slight vaccum in the engine cases. This vaccum helps seals and gaskets from leaking.
It also helps the rings seal better. This better seal gives more power and less blowby at the rings, this keeps the oil cleaner and less pressure for the check valve to eliminate.
All good things.
