vernk
Hello all! First post introduction... and then a story
just got this girl last month for $600. Was sure to get her running just before striking a deal. All she needed was a squirt of starter fluid and she fired and ran. Right side carb was leaking so shut her down quick and I pinched off the deal. Clean title w/ 40k on the clock.
Well, got her home. Ordered floats from MikesXS, installed set height and reinstalled the carbs. Well...now its a no start. Not even a sputter, and starter fluid doesn't do anything this time. opened up the points and saw small sparks when cranking. there's oil on the lower points and wires. i cleaned the area and points, sanded and set them, now no spark at all but still not sputter or run.
Just got the points/condenser kit from local yamaha and installed. Question...the two packets of goop just go on the cam? all of it? also MikesXS has a right and left points listed...is there a difference between the two? they looked the same to me.
ok Set gap at .012 then set my meter on it. couldn't get it to open circuit when moving the points assembly. just grounded out the whole time. getting 12v across both ends of both points measuring from +end battery to points. tried setting static timing for right and the meter doesnt show a break in the contact anywhere in the timing adjustment. changed gap to .016 and still the same.
coils ohm out well, changed one just to see if difference...nopes.
put it together just to see if i could get anything to happen...now the starter switch isn't working. only neutral light now on guages...somehow something got shorted or is it the points? looks like a universal points set but im guessing not oem even though from yamaha dealer.
opened up the headlight assy and theres a few cut wires in there, but just headlight and signals. everything else checks out but i'll chase a few. I'll get around to fixing them. the fuse box needs some work and i'll replace the glass fuses for now, until i upgrade the box entirely to inline as a few have mentioned here.
my head scratching goes to the points. i used the reference here:
http://www.650central.com/fsetting_pointstype_ignition_on.htm
but i guess im not understanding it.
now that im thinking, my feeler guages are new and had oil on them...that might have closed the circuit right?
well, too long of a first post? i got some work ahead of me....man i just wanna ride.
vern
vern
