SPUd
Hey all,
Pretty sure I know the answer, but just want to clarify some stuff to do with my wiring before I start putting my new harness together.
This is for the ignition pickup that, seeing I am running a BB ignition setup, I wont need, right:
Now, these are the 3 wires off of the alternator that I do need. From the diagram, I have figured out that they are:
Yellow - goes to headlight relay? Dont need?
Brown - goes back into reg/rec?
Light Blue - is for neutral switch, so goes nowhere without dash light or starter relay?
Then this is out of the reg/rec:
Black - ground
Red - 20amp fused line to battery
Brown - is spliced for some reason, on wiring diagram it shows that it goes to indicator circuit on fuse panel. I suppose I can run all the power to fuse panel off this?
Any help on this would be appreciated. I really don't think this is really that difficult, just getting everything planned out before I get into it is going to be the trick I think.
Cheers,
Ryan
Black - ground
Cheers,
Ryan
