Sound like your going to have to either learn about electrics or become very poor finding someone who
knows, (critical word of the day), and will work on these old machines, without charging you to learn about them whilst working on the XS.
Some links to threads your going to need to read to help understand the basics. With a basic knowledge and the help here, 99.99 percent of problems can be sorted.
Exellent description of how power works....................The difference, (in the link and your bike), is the description of the charging system
Simplified description; ....You have a Vape charging system which is a PMA, (Permanent Magnet Alternator), meaning it is effectively producing full power, (volts), from start up..............................factory Charging system charges at a rate to how fast the Rotor is spinning
https://www.xs650.com/threads/what-happens-when-you-turn-your-key-on.9625/
Continuity testing and how to use a multi-meter
https://www.xs650.com/threads/continuity-testing-made-easy.49917/
https://www.xs650.com/threads/how-to-use-multimeter.27826/
Grounds/Earth are vital, often neglected and can lead to problems miss-diagnosed to carbs or charging systems, where money can b spent replacing parts for no reason.
https://www.xs650.com/threads/grounds-so-important.41775/
Good thread...........
.Musings describes it well..................where a pic may be missing and there is a part # or code, do a Google search
https://www.xs650.com/threads/wiring-harness-musings.18925/
Ignition Switch can often be a restriction of full power to the rest of the system. Need to read both treads if a dismantling and clean is required............A Multimeter voltage test with the key on will determine if the witch needs a clean.
https://www.xs650.com/threads/ignition-switch-overhaul.46712/
https://www.xs650.com/threads/ignition-switch-lock-swap.54928/#post-595755
