I started using Autolite Iridium in the fall, and since then I've killed 2 plugs. I'm using the stock coil/s originally on points, now a stock dual coil on PAMCO.
I was having trouble with getting the bike to run on the right side cylinder only, and sure enough while doing a timing test with the light, the Autolite Iridium was firing erratically.
It actually has done this once before, right when I got the plugs.
These plugs aren't expensive, but they aren't cheap either, and I don't want to keep replacing them if they are junk.
So, is it the plugs, or the bike?
