Hi all,
Just to check my thinking:
The bikes a '72' and the carb mounts are quite worn and I'm going to replace them and clean the carbs.
With the choke out there's not much of a backfire, push the choke in a notch and it appears, push the choke all the way in and the bike will die unless you work the throttle which results in backfiring through the carb.
I figure the worn/cracked mounts are creating the issues through air leaks?
any advice appreciated
Thanks
Thanks
