Base gasket
yellowdog
yellowdog
UK Lincolnshire
Hi, just a quick question on base gaskets,
yes or no to sealant on a Mikes xs base gasket ,its the basic green gasket .see pic
Thanks
I didn't. No problems. As I recall the instructions that came with the gasket set said the base gasket goes on dry. If you put anything on it, it will slip when you torque the head bolts.
If it's a newer one, they are chemically treated with sealer that is released when the motor heats up - so you add none.
The head cover- or tappet cover is MANDATORY to use a sealant. Yamabond or 3 Bond is recommended. I used Permatex RTV Black. Thin bead- a thick bead will squish in and that piece/pieces will get into the system.
