Need one 41 inches from banjo to banjo.
Also, are the banjos pretty much a standard size? If not, how are they measured? Hole size?
Hopefully, he'll see this thread and enlighten me.Hey DE--Talk to 5T he gets them on line and has good things to say about them....
tim
Poifeck! Just need to run down to the shop in the morning and verify the banjo size and I'll get one on order. Thanks!Well, it seems you're in luck. Looking at pics on-line of the '83 CX650 Custom, it appears the brake line mounts to the front of the MC, so one of these cheap lines should work OK. They usually come in 10cm length increments, and 100cm (39.4") and 110cm (43.3") lengths are pretty common. A 105cm length (41.3") would be ideal for you but I'm not seeing them .....
https://www.ebay.com/itm/292880264166?_trkparms=amclksrc=ITM&aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=20201210111314&meid=318c37e0846c404bbf945fc94a74144b&pid=101195&rk=5&rkt=12&sd=314113365430&itm=292880264166&pmt=1&noa=0&pg=4429486&algv=SimplAMLv11WebTrimmedV3MskuWithLambda85KnnRecallV1V2V4ItemNrtInQueryAndCassiniVisualRankerAndBertRecallWithVMEV3CPCAuto&_trksid=p4429486.c101195.m1851&amdata=cksum:292880264166318c37e0846c404bbf945fc94a74144b|enc:AQAIAAABUObhgc4Nk8%2BdtAwOww4FKLaj%2FQ5qqgDlQCuqZA43WcPFUWDERCUugbbOk7XQv0JXlBfqCg2xKF3WcPghxGMFw2oSlXvfExEaMYr7I7LmrHcP6czY1wIMt0ORyKiCWt95xldincyyBx3g%2BNDW%2B%2FhWUgTaBhK6xAm%2BJIbCOMehu%2BdwHTocG9w16pK%2BbkNsQkY0hjTNGX%2BnaPLMAbk0g5yjStSXVmIIHsHnCfjKmxE8cdGYgDWo2GDjF0864RMY%2FXSV6SMnyUNBs2X9R0XCrejUSoDjoRLO6r%2FA2Qg3fS3uEM9q%2F5Ym85HlFbDEhF2ErDIz8WLNATU4qq3oWAMKT9dHwJWqTfoAWgr70QV8hui8sSohIVDCdLIr%2FA2TyYuHxCqPbyGe%2BWpIZvuxIzkW3UVir8BkCFdBL5%2Bz0QvHapsdgEymq549Cyn0em6Mna7q42wneA%3D%3D|ampidL_CLK|clp:4429486&var=591648462098
