If you could explain how you static balance the crank web. How you do the process a picture would help but not necessary.
Pictures definitely help. This gave me a good excuse to finally check the factory balance factor.
The first thing I did was bolt a top case to my drill press table and set half of a crank in it.
The table was tilted so that the rod could hang straight down with the crank throw perpendicular. Weight was added to the end of the rod until the crank was balanced (wouldn't fall either way when nudged).
I weighed the weight added to the rod, 180.1 grams.
Then weighed the small end of the rod, 94 grams.
Finally I weighed a complete piston assembly, 386.3 grams.
So the total reciprocating weight of a stock motor is rod end plus piston, 94 + 386.3 = 480.3.
Our "bob weight" is rod end plus added weight, 94 + 180.1 = 274.1.
The balance factor is bob weight divided by reciprocating weight, 274.1 / 480.3 = 57%.
When balancing a crank you do the same thing, only in the opposite order. Weigh the parts, calculate bob weight, then add or remove material from the crank until it's balanced.
To balance each web you would mount them between centers and hang half of the calculated bob weight. Of course, you would need to add the weight of the big rod end, bearing, shims, and rod pin to your initial bob weight calculation since they will not be hanging there.
