motorbreath
I just got done rebuilding my carbs, new float needles etc, rebuild kit from mikes. The gas was coming out of the air jets before i redid them. I put the carbs back on the bike and hooked up the fuel line opened the screws on the bottom of the carbs and gas was flowing out so that was a good sign, screwed them back in and no gas has came out of the air jets yet (knock on wood) i set the float height at 22mm, plastic floats, bs34. I tried kicking it nothing happened, battery is charged, i sprayed fuel into the chambers and kicked it over and it started but once it burnt up it stopped again. I have no clue what it is, about ready to take a match to it and watch it burn!!! Im running kick only, pamco advance unit with highoutput coil, any advice would be greatly appreciated
