I found this billet oil cooler for $35.oo and thought others might be interested. It's designed for 150cc pit bikes but I think it could be made to work on most bikes. http://shop.pitsterpro.com/billetcooler.aspx
Thoughts?
Thoughts?
Thoughts?
Space is at a bit of a premium so I've been looking at the type in your link and thinking about maybe running two in tandem one in each headlight apeture. I haven't got around to researching how effective billet coolers are so I'd also be grateful for any real world experience of billet coolers anyone can offer.
Color me silly but I don't see the point of a "billet" oil cooler.......
Isn't the idea to get air flow through the cooler?
It is HARD to find a way to mount a cooler that doesn't just dump heat back towards the engine.
Small tandem coolers, billet or not, could be mounted in places other than directly in front of the engine. Like on a crash bar or inside a fairing with ducts directing air onto the coolers.
That's my current plan, two small or one long and "squat" cooler right in the nose of the fairing with cooling slots of a corresponding size where the existing headlight appetures are (will be filling them in and recutting new slots to suit whatever cooler(s) I end up buying) - that's about as far forward of the engine and in cool oncoming air as I can get the cooler. Weight shouldn't be an issue as a small cooler full of oil doesn't weigh very much and there's no headlights or other such stuff hanging off of the fairing bracket now. If neccessary beefing the existing bracket up won't be a problem.
No headlight, we have this wonderful thing called a "daytime MOT" (I think you guys call it an inspection?) which is a version of the annual inspection/safety check that does not require the fitment of a headlight or tail light as long as the bike is only used in daylight.
This thing is a bit of a toy and is unlikely to ever need to be out in the dark
That bike lift looks cool, do you like it? Who makes it???
wow, this thing is gonna look super slick when it's done, those fairing are great. they look more 'modern'. did you make them?
several have expressed positive results with this cooler: http://www.mikesxs.net/product/15-6504.html
I would look at that as more of a filter housing, that happens to have some fins, rather than an out and out oil cooler. I would not expect much cooling, but buy it just as a filter
Measurements of oil temperature have shown that that cooler doesn't cool anything. It makes me hold Heiden Tuning of Holland in very low regard.
