Matt Isaacs
Hey all,
First time post here after buying a 1980 SG model. The bike is in beautiful shape, completely stock and unmolested, with only 6k miles on it. When I first got it, I replaced the chopper bars with a black dirt tracker bar. Couldn't get a spark until I checked this forum and learned I had to sand down both ends to get a ground under the turn signal switch and the starter. Once I sanded it, the bike fired right up and ran fine.
I spent the weekend improving some of the basics: rebuilt fork, replaced rear suspension and brake pads. But when I tried to start it, it blew a fuse. Then I noticed the left turn signal switch was loose (from when I put on a bar-end mirror). When I tightened the turn signal switch and replaced the the main fuse, the bike fired right up. But while I was letting it warm, it died after about five minutes. And again there was the blown main fuse. Now every time I replace the fuse and turn on the power, the fuse immediately blows. I checked inside the headlight switch, but there don't appear to be any loose or burnt wires. Sanded and cleaned the handlebar again. But nothing.
Any ideas?
Any ideas?
