stewart90
Any ideas/tips on taking the carbs off and boiling them in lemon juice ? I'll remove the bowl to and bowl that's about all I know for now. I'll look on you tube tonight and see just curious if anyone has done this
Soda blast, air, hot water.
You might want to search out CalsXS thread on boiling in pinesol before actually trying it. It gave a burnt look to the aluminum.
Posted via Mobile
I did the pinesol in crock pot method and here is what I can suggest. Take the carbs apart and set aside all the rubber seals gaskets etc.. Whatever you can take off that is not metal is good. My cheap crock pot only has three setting warm, low and high. I watered down the pinesol a bit to submerge all the parts and set it at high and left them over night. I dig get a tarnished burnt look after it was finished so I would suggest a low setting. After I was done I rinsed the carbs and gave them a spray with carb cleaner and used compressed air to blow everything out. They aren't very shiny anymore but they are very clean.
