bolt pattern for rear disc?
It's the same as the front??
Just found this on the web needs to be verified.
6x80mm bolt pattern
6x80mm bolt pattern
thank you sir! yea i found that on the internet im trying to convert my stock rear mag to a motocross wave rotor and i need an adapter and i cant find one so ill probably end up machineing one do u think omar would have anything like what im looking for?
You might want to look at ebay Item number:251002597354 that's two rotors for $140 there may be some offset issues but it's easier than an adapter. and they might sell just one....
are you forsure that these are the bolt pattern i need? im not questioning your knowledge by any means just want to make sure they are a direct fit
I am very high certain on the bolt pattern, virtually all the Yamaha "small" center 6 bolt rotors used the same pattern but you will need to research the overall diameter and as mentioned the offset.
