Hey all,
I have an 81 that seems to have an earlier model transmission shaft in it? I purchased one of Mikes 5th OD's (Mikes P/N 05-0870, with .979" OD) off a member here and without checking my actual shaft diameter, the gear is too small. Lesson learned: don't take the websites information as fact!
Well since I work in a highly equipped machine shop, I'm wondering if I could take the .005" difference (other part is .984" ID) off the ID myself without any harm.
The ad mentioned something about the notches in the teeth, but I'm not sure if the different OD gears from Mikes have the notches or not.
Bottom line is, will the machining affect any properties of the gear (case hardening, coating, etc.) or cause any other issues that you guys see? It's effectively only removing 0.0025" off the surface, so unless there's a VERY thin coating, I don't think I would do too much to the hardening layer, but I can't be sure.
Please let me know your thoughts, thanks guys!!
