nb1914
Trying to put my callipers back together with new pads. The manual show exploded diagram but its pretty useless. I have the below plus 2 shims ( i know where these go )
Does anyone have a good picture showing especially where that bronze clip goes, i also assume that the supplier of the pad kit has put that brass screw in for the end user to grind the last section of thread off to fit in the pad hole. Can the pads be assembled into the calliper halve seen in the photo first then this assembled onto the fixed calliper half attached to the front fork or rear axle. I have looked through many previous threads but as the callipers came disassembled I'm not sure of the start point. I have installed new pistons and seals so the pistons are set right back so should be no issue fitting over disc.
