A while back I had a brake switch on the rear only. I just made sure I used both brakes all the time. At least never the front only which comes pretty natural if you know what I mean. I used a standard Yam switch on my rear barke, just moved the mounting bracket to where I needed it and drilled a new hole in the brake pivot arm. It took a bit of testing to find the right spot. You need to be able to adjust it later and there is not much threads to move the switch unit. You can always cut the spring if need or add a link to the spring to extend it, like I did. As you are finding, thr front might take more thgought. What did they do on the older bikes with fromt drums?
