Has anyone ordered any and had them not be correct when you install them? On my new one, when I put the pin through the posts on the carb body the notches on the "backbone" that are supposed to hit the post to keep the needle from falling out are way to far from the posts.
No matter where I set the tang the notches don't hit so when I flip the carb to operating position they fall straight down and the needle falls out. I noticed the part on the "backbone" which accepts the pin is pretty shoddy and not closed fully. It is also not at the correct angle.
Do most come this way and you're left to finish the part? I understand adjusting the tang for the float level but I really don't want to pinch the pin receiving hole (for lack of knowing what that area is called) or snap the floats off the "backbone" trying to adjust the angle of the pin receiving thingy. I emailed MikesXS explaining the problem and I hope I'm not totally out of line if they all come like this (which wouldn't make a lot of sense.) Any input would be great.
If push comes to shove I can take the floats off the "backbone" and solder them to my old "backbone" but really that's not what I paid for. I hope I'm not totally wrong here.
Thanks, Ryan
Thanks, Ryan
