Both of mine seem to do that too, run a bit "rougher" on the left side, and both have electronic ignition. But even when I still had points on the '78, it was like that. Maybe just another 650 "quirk"? You may be able to minimize it by making sure the timing is set exactly and the points set is good (gapped properly too). And speaking of the points gap, using a dwell meter is the best way to set it and the only way to accurately set used points. As I'm sure you're aware, the points develop pits in the surface as they wear. But maybe what you don't know is that's where they fire, between the pits. So, it's impossible to measure that gap with a feeler gauge. The gap you've measured and set with the feeler gauge is actually smaller than the gap the points are firing between. To compensate for this when using a feeler gauge on used points, it's best to set them at or near the minimum of the spec (.012"). Also, you'll want to eventually check your timing with a timing light. The static method of setting it isn't always that accurate.
