bwthor
So, I pulled the carbs all apart, carefully setting the parts aside. Cleaned everything up, checked all passages and started assembling. About half way through, I looked down and these two rubber washers appeared, and I have no idea where they are supposed to go. They are in the lower right of the pic.
I just can't figure out where these came from. They are the same outer diameter as the brass washers between the main jet and the brass venturi tube, but have a slightly larger inside diameter. About the same thickness. They are flexible, and I'd guess made of rubber.
I've looked at a few diagrams, but I'm missing something.
Thanks in advance!
Thanks in advance!
