Hi out there. Anybody ever used a "Syncrometer" (carburetor airflow meter) to adjust their carbs on an XS? A friend of mine loaned me this device, claimed it works well. The idea is you plug this into the inlet side of a carb, then adjust the mixing screw for the specified airflow, then move it to the second carb and adjust the mixing screw so that the airflow matches the first carb, seems simple. Only problem is that I don't know what the air flow should be. My thought would be to adjust the first carb, lets say the left, using the dead cylinder method, then check the airflow with the "Syncrometer", then adjust the second carb (right) using the "Syncrometer" to match the first. Any thoughts on this?
