Id put a few miles on it and read the plugs before I made any jetting decisions.Hello, so I have replaced my destroyed air box with unifilter foam pods, and read on the package that I should increase my jet size on my BS38 carbs. Anyone have an idea of what size I should go to?
Well it's a project in process, so I won't find out until spring. But I imagine I can wait.Id put a few miles on it and read the plugs before I made any jetting decisions.
With BS34's and foam pods I did not need a re-jet, just turned the low speed mix screws out roughly 1/4 turn.Well it's a project in process, so I won't find out until spring. But I imagine I can wait.
I'm aware of the need for more fuel in regards to the higher air flow associated with the unifilter, but I was looking to see if anyone had already done the work and determined the best sizes to use.It’s all about air fuel ratio. I think it’s 14:1
Pod filters let more air in, so you’ll need more fuel.
I had made a slip on pipe with a welded bung. Have a gauge set up. Never did finish it. Haha These carbs work in a series. Idle first. There’s a chart on here if you search. If you’re idle is fine, doesn’t mean the mains are ok. Sorry if I insulted your intelligence. Also these carbs are decades old. Don’t assume they have the right parts inside. I just found missing orings in a set. Took a good long while to figure this out.
How can you tell what carb is what year?Yes, you'll need to positively I.D. the year of your carb set and then base the re-jetting on what came stock in that particular set. You base your jetting and/or re-jetting on the year of the carb set, not the year of the bike.
Mike's XS has a carb ID chart. My 81 Special has 76/77 38's on it.How can you tell what carb is what year?
These have of course been cleaned and rebuilt since then.Yes, there are little "tells" on the various carb sets so if you can show us some pics of yours, we can probably help I.D. them for you.
No, that's a '74-'75 set. The "tells" are the #120 butterfly plates and the lowered floors in the main bores. '73 and older carbs use #125 butterfly plates and have a raised floor in the main bore .....
And because of that raised floor, '73 and older carbs use a longer needle jet .....
'74 and later carbs use a shorter needle jet .....
