pregrid
XS650 Guru
Finally got the pistons out of the calipers, not the easist thing I've done here. One came out with air pressure, the other I had to hook up the front master to and use hydraulic pressure to remove it.
Question: all the caliper rebuild kits I've used in the past (mostly automotive) came with a little packet of grease to lube the piston seal. Don't know if the kits I've ordered from MikesXS has them, doesn't look like it. What do you guys use to lube the seals? I'm pretty sure just any grease won't do cause petrolium based grease and rubber generally don't get along.
'preciate your help
'preciate your help
