For a year or two or five, I've been advocating adjusting the cam chain by turning the adjuster as tight as you can with fingers alone, the theory being it takes up the slack but with fingers alone you can't turn it tight enough to overtighten.
That worked fine with a normally gunked up adjuster, HOWEVER, I was surprised to discover that with the adjuster assembly completely cleaned of gum and gunk, it's easy to tighten with fingers alone to the point where there is no inner plunger movement at all. So...I'm back to the normal method of tightening till there's a mm or two movement. I'm trying to chase something else down, and next I'm going to try loosening until the chain rattles, then tightening only until it doesn't.
