While setting up a new Boyer Bransden ignition I found I could not match TDC and the full advance settings as per the installation instructions. It has been suggested to me that the timing chain may be out by 1 or 2 teeth.
Is there a way to check the timing cam position relative to TDC without pulling the engine and physically looking? I have confirmed that the crank TDC marking matches with the pistons at TDC.
I noticed that on the right hand side of the camshaft where the ignition advance mechanism fits there is a hole drilled for the locating pin. Does this pin hole correspond exactly with the cam alignment mark? A google image search suggests this to be true but I could not get a clear enough image to be 100% sure.
When I set the crank to TDC the pin hole on the right hand side is in a true vertical position.
Thank you for any advice you can offer me regarding the alignment of this pin hole as a check on the camshaft setting.
Thank you all and have a very enjoyable festive season.
Note:
In thread "cam alignment w/ pamco" XSLeo said "Yes, the tensioner will change that cam position slightly. As the tensioner applies tension on the chain it pulls any slack in the chain to the rear of the engine. This pulls the cam backwards a bit.
With the timing marks at TDC look at the other side of the engine, where the stock advancers is. The pin that aligns the advancers up on the cam should point straight up or down. Depends on which cylinder is at TDC.
If off one tooth, the pin will be off by 10 degrees. If you imagine clock face around the advancer and the pin should be at 12:00, if off by one tooth that would have the pin at either 2 minutes before or after 12:00."
Thank you XSLeo.
What a dope I am, I should have searched better before jumping for the New Thread button.
Wishing You all the Merry Christmas - Paul (Dope)
Note:
Thank you XSLeo.
