C-Los SD
Got a possible issue with my cam chain tensioner install. I started with 73 TX650 256 motor. I had installed a 447 rephased crank and cam and new cam chain. I reused the original lower chain guide and tensioner (pic below) and buttoned everything up. In the process of reading about valve adjustment, I came access a post about when swapping 256 to 447 cranks to change the cam tensioner, but nothing really definitive. My problem is, I already sealed up the motor and have everything perfect and don't want to wait for new gaskets and clean off the three bond and start all over in order to replace the lower guide.
So, can I reuse my old style guide and tensioner with a 447 crank and cam, or do I have to change it all over.
Thanks
Thanks
