luckynumber0
In Over His Head
Hey all,
Was in a great mood this morning as I began wrapping up my rebuild on an '82, which all began due to a worn cam chain guide. Everything has been smooth so far - cleaned everything like never before, replaced rings, replaced cam chain & guide, got barrels honed & head inspected/cleaned/valve job (inc. seals) at a very good machine shop, and have been taking my time with everything so as not to screw anything up.
Well, today everything went back together with ease but when it came time to put the cam chain on the cam, i noticed that when I aligned the crank to TDC via the rotor, the chain was not even. Luckily there seems to be enough for me to link them with the cam & crank in correct positions and on top of this the chain is much too tight to meet for the master link.
I read on here that the Athena head gasket from mike's is thicker than OEM, which would make sense because the amount of give that the two ends of the chain would need to meet is quite small...however it doesn't want to give.
I thought about taking the bearings off one side of the cam, linking them up, and then lifting the cam and shoving the bearings on once it clears.
Anyone have any experience with this? Also, did I fuck up putting on the new cam chain somehow if where they meet is not at the index mark on the cam when aligned in TDC?
