BobberNick
OK, I need your knowledge!
I bought some wire wheels last night from a local guy for my 650 project. I'm almost positive that these rims didn't come from an XS 650. As you can see the rear wheel drum has a sprocket attached. It's a really cool look, but will it work if I use correct spacers? Also, the axels for these wheels are smaller than the standard ones used on my XS. I'm not sure what year my frame is, because the Vin has been painted over with some really head paint.
So, my questions are, could I run the drum/sprocket combo if I space it correctly for chain alignment and run linkage for the opposite side brake pedal? Also, can I run the smaller axels without problems? Do I need to run some sort or insert into the larger fork legs on the front and back axel mounts? I hope these questions are stated clearly.
Thank for your guys help. This is the ultimate MECCA for XS info!
Bobber Nick
Bobber Nick
