I recently bought a '79 xs650 and the carbs have been leaking a little fuel out of what I assume is the overflow tube. I hadn't looked too closely at what carbs where on the bike, low and behold they aren't stock!
I found some scribbled notes in his old shop manual mentioning Mikuni 36mm VM carbs, can anyone ID these for sure or know what I should look for? For reference the setup is aftermarket tank with single petcock -> fuel filter -> T'ed off to feed both carbs which are totally separate from each other.
I was originally thinking the petcock was slowly leaking as well but the bike has sat for a few days and when I looked today the inline filter was totally empty so looks like it is just the carb float at fault. Anyone happen to know what the float height spec is for these carbs?
Thanks!
Tony
Thanks!
Tony
