Capt_Zoom
Raider Rider/xs newbie
For 1980 Stock BS34 carbs.
I want to install the canadian needle and needle jets. I vaguely remember reading somewhere that one needle should be in one clip position while the other in a different position. Does anybody know where I find this info or remember?
Basically, I'm having a hell of a time with my carbs. A dealer installed new throttle shaft seals and now all hell is breaking loose. Stuttering bad at 20-40mph. Idle is way too high and I can't get it down. I've resynced carbs. Getting 12 inch of vac on those guages.
At present the pilot and main are up one size to accomidate the straight unbaffled pipes and the pod filters.
I got a bad feeling that the butterflies are off center so I'm going to remove the carb and check out, will likely add the needles then.
About ready to punt the carbs across my garage.
