pnedac
Well I finally got the bike up and running, but not without some trouble of course. I can seem to get the timing to relax. I am running a SPARX and a Boyer Branson ignition and it starts and I ken get the idle to be okay, but as soon as I hit the throttle it jumps way higher in RPM and won't come back down unless I retard the timing, but then I am retarding the timing past where to needs to be and it'll die. Reset it and it fires right up. Then I get it dialed in and then I hit the throttle and it jumps up. Vicious cycle I am caught in here. Anyone have a suggestion on something I might be missing. I have ridden it and it will idle too high until I put it into gear and then it seems cool until of course I go back to neutral. Same vicious cycle. I am officially confused. Cam Chain set, valves set, white paint dot lined up behind the magnetic advance and engine at TDC. I am missing something? These are also brand new carbs professionally set up by MMM at 650 Central so I am trying to stay away from jumping into them if at all possible. Could be there too though.
Any help is appreciated.
