Can someone point me in the direction of ways to distinguish between 70-73 carb bodies and the 74-75 bodies? Same thing with the bowls. Is there any interchangeability between the bodies and bowls on these years with the difference in the needle jet? Bowls are marked with an A on the bottom, but one of the bowls has something else stamped in the same location.
Trying to figure out if the carbs in the images are actually 74-75 as the brass indicates. Pilot jet is Mikuni 45. Main has been replaced with a no name 128. Needle jet is the Mikuni short Z-6 with a fresh O Ring. Needles are 4N8-4.
These came with a batch of early bikes and parts I bought a while back.
Plugs indicate everything is way too rich. Trying to figure out if it is the no name main jet or a mixture of incorrect brass in the wrong bodies.
Thanks in advance.
Thanks in advance.
