Some info first. Saturday I received a set of VM34 carbs. After some basic tweaking bike was idling ok. It seemed like it idled best with the mix screw all the way in, so I'm guessing I need a little bigger pilot jet. But, it still started, and idled pretty well.
I took it out for a test drive. I was worried as to what may happen when I gave it some gas. I was thrilled when it took off like a bat out of hell. It ran fast, really fast. I was hitting 80 mph fairly quickly. So , happily I parked it, went online and ordered a few jets.
Yesterday I went to start it, it started up, but I realized the right cylinder was not firing. Turns out one of the cable ends that goes into the 2 way splitter was hung up a bit. Its hard to explain if you don't use one of these. Anyway, I got it started again, the right cylinder coughed and sputtered back to life. So now I hook up my vacuum gauges to sync the carbs more precisely,
and something weird happens.
When I give the bike throttle, the left side makes the needle go up, but the right side makes it go down! I have never seen this before. But, at idle the needles are in the same spot, which is good. So I take it for a ride today, and it is behaving completely differently than the maiden voyage. It is pretty smooth all around, but not nearly as aggressive. It doesn't scream at all now, but still cruises ok.
What could make a vacuum reading go the opposite direction? And is that reading related to why it no longer blasts off like a rocket.
Will keep this post updated as I get the time to mess around. I will have the carbs off when I get the new pilots, and I will also borrow my friends compression tester on thursday. Any ideas ahead of time would be great. Thanks.
