pa23driver
So i'm trying to tune the stock bs38's on my 1977 standard.
my current setup is:
mikes 1.5 inch pipes with commando mufflers
new JBM diaphragms and manifolds
needle and seats replaced last year
UNI filters
130 mains (pulls really nicely up to redline)
needle dropped a step (#2 position)
carbs freshly synch'd this morning
valves adjusted (.003 intake, .006 exhaust)
pamco iggy timing reset
carbs were cleaned last year using the carb guide, also installed fuel filters.
here's the problem:
i'm getting the flat spot just off of idle and the idle is hanging when i blip the throttle, all indications of too lean pilot jet - makes sense since i dropped the needle.
i pull the plugs to double check my reasoning. the right cylinder is showing what you'd expect: a light smoke ring at the base of the ceramic with the rest of the ceramic white and the electrode slightly white/grey. i pull the left cylinder plug and its black/grey with just a little white showing on one side of the ceramic.
what could be causing the difference between the plugs? float level? dirty something-or-another? trying to figure this out before i start changing jets again.
UNI filters
here's the problem:
