XS650D
XS650 Junkie
I have a 77 with the stock 38,s and they run great BUT after having a 1980G with the 34,s i feel
that the 34,s are better. The fuel flow makes more power down low and in the med range were I feel
the 38,s make better power in the upper mid range to full throttle range.I have my 38,s dialed in pretty
good I feel after experimenting with different jets, needle positions and shimming ect.They just dont
have the same pull on the motor below 4 grand. Off the line in 1st gear it pulls great but if your just
cruising round at 2 or 3 grand and pull the throttle it just doesn't have the same pull .Im not sure if this can be
dailed out.I am running the stock front gear and 1 tooth down on rear gear (33 tooth) I may go back to
the stock gearing to keep the rpms up around 4 grand as your always on the power band with those gears.(The 33 is nicer on the Hwy when just cruising)
I have experimented with another stock 77 that has the stock gearing compared to my geared down 77.
The 34,s may have a lean problem in the mid range based on what I have read especially if you add pods
and pipes but looks like it can be cured with Canadian needles ect.The compression numbers are down on the 76/77 compared to later and earlier years also I noticed, this may have an impact on the way the bike runs also but cant confirm that. I have also experimented with Timing quit a bit and noticed that a retarded setting smooths out the
power band and also lets the motor run cooler BUT at the cost of some slight loss in performance .
Anyone experience this and find a mod to make the 38,s run better in the bottom end.I think that its the typical bigger makes more power but for the type of riding the 650 is designed for the 34,s just work better.
Just my personal thoughts and observations after riding and tuning this bike for 3 years. Still without a doubt the nicest all round bike I've ever had the pleasure of owning!
