1. Dismiss Notice
    Dismiss Notice
Wanted - Cast Wheels
Discussion in 'Classifieds' started by wrmdovr, Mar 23, 2017.
  1. wrmdovr
    wrmdovr If it were easy.....everyone would do it!
    Looking for set of cast wheels.....I live near Seattle, WA. WRMDOVR
  2. you looking for disc rear brake or drum rear brake ?? I have both and front wheels also
  3. wrmdover, search craigslist ptld parts. Albany Ore, set of cast wheels there I've noticed -RT
  4. Ratranger
    Ratranger XS650 Junkie Top Contributor
    677
    1,745
    143
    Oklahoma
    I have a set of stock cast wheels from a 78 in spanaway, closer to puyallup than tacoma. For the right price I would even separate them from the forks and swingarm. Front is 19" rear is 16".
  5. I have a front with disk for $50.00 plus shipping (tire will be removed)
      File size:
      52 KB
      101
      File size:
      60 KB
      93
  6. wrmdovr
    hey Dirty Dog....need disc on the rear and I remove the disc from the front......I am just that kinda guy? :) WRMDOVR
  7. wrmdovr
    hey Time.....thanks for the heads up! WRMDOVR
  8. wrmdovr
    Yo my man Ratranger......you are talking my language......shoot a price and like Monty Hall used to say, "lets make a deal" WRMDOVR
  9. wrmdovr
    Hey Daddy.....i feel kinda weird say hey daddy...:-(? anyway.....appreciate the info and if things dont go here in the PNW i will message you. WRMDOVR
  10. brianmac
    brianmac XS650 Enthusiast
    any body got a rear cast with a drum wheEL?
  11. harpo57
    harpo57 owner of basket case
    Hmm do you have spoke wheels? Trade for my 79 special cast n disks?
  12. brianmac
    I have a bunch of Wheels and a I have not decided which ones I'm going to use most have Rusty spoke s can I put stock cast Wheels on on 1983 heritage
  13. harpo57
    N.
    Hi! well swapping wheels is something i need alot to learn... lol.
  14. brianmac
    I got a busload of parts this week couple of headlights no bucket ignition boxes regulators brake pedals wiring harness light bulbs For instrument panel calipers Wheels
  15. 650Skull
    650Skull SSSSSSSSSlither Top Contributor
    Bit of a high-jack going on here. Best to start your own Classified thread.............
    That being said..............only an 81SH cast mag wheels with drum brake rear mag will drop straight into a Spoke wheel swing-arm, (74-83), without modifications.
    78-80 Cast mag wheels swapped into a spoke wheel swing-arm needs modifications done to the swing-arm, (brake stay position change and brackets), and frame. needs mounts and brackets for the M/C and reservoir. Also need to swap the Brake pedal shaft to a Disk brake one required to work the M/C.
    In reply to post # 16
    I have posted this information as a help to the thread and also as a note and advice for those high-jacking someone else's Classified thread.
    I will not respond to any further posts in this thread. I will respond and help where i can in any new threads.
    gggGary likes this.
  16. brianmac
    So I got a 78 rear cast wheel with drum brake ,won't work in an 83 heritage with spokes
  17. brianmac
    650 skull u da man, tks . now will therear spoke brake assembly fit the cast wheel assembly? the part numbers are the same but for the last 2 digits?
  18. There is no '78 rear cast mag with a drum brake, they are disc brake only.
    If you have a rear drum cast mag it is from an '81.
    A rear drum '81 mag will fit an '83, all brake drum parts will interchange.
    gggGary likes this.
  19. gggGary
    :agree:
    Or "some other bike".:poo:
    nj1639 likes this.
Share This Page
