bigmark0272
Hey buddy showed me this one and it works awesomely. First you block up riding mower rear wheels off the ground. Then cut plywood pieces near the size of the tire. 1 piece on needs center hole split to go around axle then couple boards holds back together. The other plywood needs 2x4s running parrallel on opposite 2 edges. Next screw boards running parrellel with other two sides (perpendicular and on top of 1rs boards) which will leave gap between boards and plywood. Nowy ou can either used 2x4 or 1x4 to attach plywood together building box around tire or use straps. Once thats done you can attach tank to another piece of plywood or directly to last boards using straps depending on your tank. Then after making sure the tubes and holes are plugged (if neccessary) You can fire up your mower, engaging tranny to desired speed and let it do all the work of spinning shaking your tank!! If I'veconfused you guys and would like to see it let me know I'll be doing it pretty soon on mine and will take pics.In the past, I've used blue metal. Put a few handfuls in the tank and shake until your arms fall off. To remove any remnants of water, I've used metho.
