NDSinTX
Greetings. This is the first post in this thread - it pertains to a 1982 XS 650 Heritage Special that I acquired last Sunday. It had spent the past 25 years in a storage warehouse in Llano County, Texas, and is now residing in Wimberley, Texas.
The bike has 13.2K miles on it and other than cosmetics and a dog-eaten wiring system, it is a very nice donor. My intention is to turn it into a street tracker, but on the advice of some in this forum (I'm a retiree and first-time "builder"), I'm going to take it down and try to get it operational in more or less its original form, minus some of the unnecessary weight.
As I go through my check list of things to do, I'll come to this forum for advice. The first topic has to do with wheels and tires.
The tires are both flat, and seem to be tubed. I'll pull them both off and get them fixed enough so that I can at least roll it around. I have no intention of riding it with the existing tires.
For the eventual street tracker build, I had intended to replace both the wheels and the tires, probably with 18's. However I like very much the odd lacing style of the existing wheels, and am going to use them both now, and possibly for the full build later. A photo of the front wheel is attached - you can see why I'd like to keep it, it's about 60 percent through a clean-up and it will come out with very little permanent damage.
My questions are:
1. The tire is a 90H19 Avenger, made in USA. Looks to be original. Assuming I stay with the present wheel/rim, what is a suitable tire to be used as a replacement?
2. I cannot use a tubeless tire with this rim, is that correct?
3. If I wanted to go with a 100x19, can that be done without other adjustments? (I am not putting the front fender back on, though I'm likely to reassemble with a fork brace.)
4. The brake rotor photo shows little tabs that stop the rotor from coming unbolted. In order to remove the rotor, I'll have to bend the tabs up. Will the tabs be reusable, or will I have to replace them with new ones? If so, where to get them?
Tks,
S.
My questions are:
Tks,
S.
