dimka pdx
Hi guys,
I have been building a project off and on for a year now, and getting very close to that first ride. However, just like any project with a fair amount of mods/fabriaction, you are sure to run into something that doesn't fit.
A little background: The bike is a 81 XS 650 Special. The idea was to build a cafe looking street bike. The rear suspension is a Ducati monoshock, and I actually had to redo it a number of times before it worked well. Either way, because of the monoshock and the current ride hight, the chain hits the top of the swingarm. See pictures below (of issue and project in general).
WHAT WOULD YOU DO to fix this dilemma? Keep in mind that everything is already powdercoated, but I can definitely grind and weld on the swingarm.
I have read plenty about sprocket tensioners, but they look like they take a fair amount of space. I could do a skateboard wheel tensioner, which is also a space commitment in already tight confines. I have thought about hard mounting (two tabs...no spring) a small sprocket since I can control the tension with the rear adjusters...what do you think? Also, hard mounting a skateboard wheel?
Most of the tensioners I see are mounted on the bottom...but I need to put it on top to fix the issue. Is this okay? Would love to hear what the gurus on this forum would do.
And here is a work in progress pic from this summer:
