XS650D
XS650 Junkie
This is for my 77D.Note i am running Uni filters,with 30 pilots,Needle dropped 1 (Leaner) 135 Mains.Gearing
17/30.Stock motor. I just installed new Mikes Commando Muffs on my Mikes manifold upswept pipes.
(I had BSA style pea shooter Muffs with custom baffles and Packing) I am getting some running problems since adding these New Commando,s.Starts fine,idles fine and pulls off the line good but flattens out around 4000 to 5000 rpm then its like a switch is flipped and the motor surges from 5000 to 6000 rpm on and off up to redline.Not really sure were to start on jetting changes.Starting to think it may be the lower gearing throwing the power curve or band but not sure,may be jetting.Any ideas were to start.Could that be timing not set correct.Cruising around takin it easy motor will run good up to 4000 rpm then everything goes south from there if i throttle hard.Another guess is my needles set to rich and mains set to lean but finding that hard to believe with what i have in there.I had a buddy ride it and he says it feels like the mufflers are not letting it breath at 4-5 grand as they go quieter.
