If you're using a brand new gasket (or a used one in good condition), you should only need some Permatex gorilla snot.
The sump only requires a gasket................no sealant needed.
Could some of the problem have been from applying the gasket dry?
There was little to no oil on the crankcase bottom, and no oil on the sump plate, so the new gasket may have been installed bone dry.
I rebuilt my 305 Super Hawk back in 1969. i wondered about installing new paper gaskets dry or smearing with grease. Honda said to install gaskets dry as oil leaking would swell the dry gasket and stop the leak. Made sense so that's the way i install paper gaskets unless I get specific instructions otherwise.
Tom
