About a third of the time when I turn the bike off in 1st gear with the clutch pulled I hear a clunk. It sounds sort of like when the kickstand flips up and hits the muffler but it varies in loudness. It doesn't happen in neutral. No bad sounds when running. Not happening in neutral and happening with the clutch pulled makes me think it involves the clutch. The part about only happening sometimes and varying in loudness, makes me think it is driven by release of compression, or maybe valve spring compression. Any ideas? I noticed it after a rebuild, and as far as I know the clutch is right. Put together from diagram showing the missing washer. Using Mike's throwout bearing with its extra bearings.
