mrpink
- Messages
- 91
- Reaction score
- 0
- Points
- 6
Got on the bike this morning to go to work, started up like usual, backing it out of the garage, had the clutch pulled and the bike in gear, no problems. Let the clutch out half way to stop from hitting my wifes car while rolling back, worked fine. Went to pull the clutch back in and heard a pop. The cable pulled out of the barrel retainer on the hand control. Shifted into a neutral just fine and I pushed it back into the garage- took the truck to work.
Got home, pulled the clutch hand control off, popped the barrel retainer out- it snapped in half right down the center. Got to thinking about why this would have happened, got the clutch cable in some vise grips, it seems like it will not pull at all. The cable "seems" free... I have put almost 1000 miles on the bike this season already without any issues.
My questions are. Should I be able to operate the clutch by pulling on the steel cable (the outer portion was in the holder on the bars). If all I need is a new barrel retainer, that seems like a pretty simple fix- is it? Could my clutch be locked up? What else can I check before tearing the cover off?
Thanks.
p!nK
Thanks.
p!nK
