NastyBeads
So I finally got the bike running /idling on its own. I knew I had a problem with the clutch but thought I found the issue. The clutch lever is SUPER hard to pull, and in reading I found that this was kinda common with this bike. I also found that I was missing the ball bearing in the worm gear, replaced it and didn't solve the problem. My issue is that the lever is super hard to pull and doesn't engage the clutch. I figure it's stuck for some reason due to time because I found that issue with other things on the bike. I tried rocking back and forth while in gear to free it up, no joy. I'm going to open up the right side (again) to see if anything is appearant. Any suggestions on what I should be looking for? Could I give a couple blows on the rod with a rubber mallet to try and free it up?
Also, the ball bearings and rod were lubed well and clutch cable is new if that helps.
Thanks in advance.
Thanks in advance.
