pa-powerstroke
On The Edge
Just got an extended clutch cable from mikes, works alright just a little stiff. Bike is currently not running and has not had oil in it in about a month. So even with the clutch cable shortened all the way there is no slack or play in the lever, is this normal? Also when I have the lever sqeezed in all the way I can put the bike in first but with the clutch lever pulled in the rear wheel will turn but there is a lot of resistance. Makes it hard to push the bike in first with the clutch engaged, doesn't seem normal. Is there a problem here? Im just afraid the clutch will still be grabbing when the bike is in gear and running.
