Jiles
I have read many post on this forum about slipping clutches but haven't found my answer.
I have a 1981 XS650 Special with only 5K miles on odometer ? ? Although I have no way of verifying mileage is correct, condition of bike suggest this is correct. One reason being tires are original with plenty of thread but signs of dry rot. They will be changed.
I didn't notice clutch slipping when I bought it because it was running so bad. Clutch cable was lubricated and adjusted correctly and slippage is noticed even in fifth gear accelerating up a slight hill.
I inspected all clutch friction plates and they measure a tad over 3mm with slight discoloration on some of the steel plates.
New OEM Yamaha springs measure 0ne mm longer then original.
I changed, what looked like new oil, cleaned both filters and found very little contamination.
I changed to Chevron Dello 400 15W40 because that's what I use in nearly all other small engines, along with my 1976 MGB Roadster and Kubota diesel tractor.
With what I have found, could the Dello oil be the problem?
