Grizld1 when I first got the bike running a cold compression check with no carbs on showed
120 left and big fat 0 on the right. I ran some ATF through the right cylinder and rode it to the Ozarks rally with those cold numbers.
At that rally (John will attest) I had no trouble steppin off if I wanted.
Per the suggestions I next tried a cold motor with an open throttle and got.
Left cylinder.
And the right.
That is looking better with only <20% difference in the cylinders. So the amount of air you let the cylinders have does make a BIG difference.
Now lets look at gggGary's test it warm suggestion. It didn't take maybe 10 minutes to bring the temp from.
To (and actually it gained a bit even after I shut down because of the delay between what the motor is to heating the oil which is what the gauge is reading)
At this point you will want some gloves to remove the plugs unless you one tuff sumbeech or you have no nerves in your fingers, so have a pair handy.
Also as a caution/warning even though I ran the carbs dry and only one cylinder had a plug it still tried to fire off and run for a moment.
Warm motor WOT.
This is the left.
Warm and WOT. Drum roll for the right.
And just for sheets and giggles.
Warm and closed throttle.
So if you have rescued a bike and think you have bad compression on a cylinder.
Test it correctly and ride it for awhile, the numbers may improve. That instant right now, get into the top end to fix it may not be necessary.
Side bar as the cam chain is into aluminum it will be time to freshen up the top end this winter and I fully expect with a set of new rings, cam chain and front guide, and clean up the head it will be
good as better than new.
