staf0s
Found lots of fuel and a little bit of grit in the oil as well as globs of what looked like melted plastic. Turns out it was pieces of the rubber bushings that are on the head studs. Figured I would replace the chain guide..yada yada. When I got the guide out, I noticed that it was perfectly fine and looks brand new. The bike is an 81 with a little over 13k miles. After inspecting everything, it all looks really clean. There was a little but of carbon and slight corrosion on the tops of the pistons but it cleaned up nicely.
I have not removed the cylinder bore yet.
So after doing a little more looking around I noticed that there is a gouge on the cam and and some markings on the bearing that’s closest to it. Does this warrant a reason to replace the cam and bearing? Or leave it?
Leave the factory chain guide or replace? The factory one is to the right of the MikesXS guide shown in the pictures
I’m still at the point where I can replace gaskets and put everything back together and call it a day.
Is it worth pulling the barrels and getting them honed and replacing piston rings? The only reason why I can justify doing so is because I originally planned on getting the casings and the top end cleaned up and refinished/coated. I also have a chipped fin which irks me. Now would be the time while everything is apart
I’m including pictures. What do you think? Put everything back or continue along?
