xs650newb
Hey everyone,
As I've said in previous posts I've had trouble getting my newly rebuilt engine to start. Compression is good, valves, and camchain are set, and the carbs are clean.
I am letting the engine turn over with the starter motor and I pulled a plug and grounded it to the engine. The spark only comes very sporadically and is very weak. (It is the same with two function ignition coils).
I measured the voltage at both the red and orange wire which go to the coil.
Red: 13.? volts
Orange: 0 volts
Is this normal? I thought orange and red should both be at battery voltage.
If this is the case and my CDI is connected properly, what does it mean? Is the CDI box bad?
Best,
Adam
Red: 13.? volts
Orange: 0 volts
Best,
Adam
