Copper sealing washers.
jetmechmarty
Project collector
XS650.com Supporter
Coldwater, Mississippi
I had hoped to find this in the TECH section, but I failed to find it. I'm getting ready to put a bottom end together and I wish to gather all the copper washers for this bike in one order.
I found M8 with a 12.4 mm outside diameter to go under the six crown nuts on the bottom.
I need:
The four for the left case cover. 90430-06014-00
All of those required for the oil feed tube unions. 90430-10171-00 and 90430-14043-00
Two that go under the holder for the front cam chain guide. 90430-11033-00
I already have those for the top of the engine. My hope is that someone already recorded these, and I simply failed to find it.
I'm attempting to but this whole mess from McMaster-Carr.
My local Ace Hardware has a good selection of metric coppers.
Ymmv
You’re fortunate south of the border to be able to get such things at a local hardware store. For me it’s online shopping or special order from an industrial supplier.
A nearby "Runnings" store has quite the extensive hardware section. Check them out, if you have one in your area...
sounds like a remote place you live in, so best option may be to reuse old copper washers. There are better option than copper for sealing, in my opinion, alu or stainless steel washers with bonded rubber in the center, keeps the oil where it's supposed to be. Downside is they can only be used once. I don't know where to get them in US (in metric), probably an MC store that deal with european or jap bikes - I know they were used on BMW's.
I had a bunch from when i lived in Europe but my stock is running low so unfortunately not able to spare any. they kinda look like this
https://www.pegasusautoracing.com/p...bHQXuzKJVRbbZ9ncvJdiv_FNwLHeZub0aAh45EALw_wcB
Seem to work just fine - even on hyd. brake fittings;
https://www.amazon.com/Assortment-SELIKOUR-12Sizes-Sealing-Washers/dp/B07HFMP8DW/ref=sr_1_14
I buy a lot of specialty stuff from McMasterCarr, but sometimes Amazon is just too easy:)
Bought a similar kit on Amazon too. They all seem to be the similar but I bought the kit with thicket, large diameter washers. Most were 1.0mm thick.
I bought sealing washers from Fortnine. Had one banjo bolt I couldn’t get to seal with copper or aluminum washers. The sealing washers worked well.
https://fortnine.ca/en/drag-specialties-banjo-bolt-sealing-washers
Between McMaster-Carr and Amazon, I should be in great shape.
